The definition of a load board
soodamanikannan
Member level 5
Coimbatore
Any body can give the definition for load board, or any web reference and web links.
Re: What is load boards?
It could be a kind of simluating the actual load without really using that.
Here you have loads(for eg- resistors in case of electronics/electrical applications) equivalent to the actual load and do the preliminary testing.
A load board, interface board, or DUT board is a circuit board designed to serve as an 'interface' circuit between the automatic test equipment (ATE) and the device under test (DUT).
visit following link for more detail:
ATE Load Boards/DUT Boards/Interface Boards
hope it helps
regards
SA
