The comparison of Nanosim to Hspice
Ruritania
Member level 5
Has anyone ever verified the design with Nanosim and successfully taped out?
Nanosim has faster speed, but Hspice is always the golden standard. I'm really wondering which one I should use... :(
Pls give me some suggestions, thanks.
Ruri
leo_o2
China
Re: Nanosim vs. Hspice
Nanosim is better for mixed-signal circuits. It helps much for function verification.
If you want to get accurate simulation for small circuits, Hspice will be better choice.
khorram
Full Member level 4
Nanosim is useful for system level design and verification where you just want to verify your algorithms. But to simulate in circuit-level, you should use Hspice, because its algorithms are very powerful and in the most conditions can converge to the correct results. As you know, in this level the number of components are large and you will get lots of differential equations with higher orders. But other analog simulators don't have efficient algorithms for circuit-level simulation.
Regards,
KH
xieyan2001
Junior Member level 2
Nanosim use partition technic to accelerate its simulation speed.
But its model is not as accurate as Hspice
Yun Lin
Member level 4
China
Nanosim vs. Hspice
Sometime, the nanosime is only choice because of hspice can't handle large system.
feier0251
Junior Member level 1
Nanosim vs. Hspice
for vlsi mixed signal ic,nanosim is better for post simulation.and hspice is better for front simulation.
regards
flushrat
Full Member level 3
nanosim is suit for post-simulation and some conditions that you just want to get a rough estimation about a circuit.
Hspice is necessary for pre-simulation and post-simulation of some important circuits
mitgrace
Full Member level 6
Nanosim vs. Hspice
In my experiment nanosim is fast hspice .. It is less accurate 5% than hspice . In the some critical block . like ADC , I thinkyou must do it using hspice
eejli
Nanosim vs. Hspice
first time to hear nanosim.even hspice is not that accurate if the speed s high especially for RF circuits.
Manjunatha_hv
Advanced Member level 3
INDIA
HSPICE is accurate & mean time it can't handle large circuits...
