The AVR and PIC microcontrollers
pic16f84
Member level 4
libya
+advantages +of atmel/avr
why avr using in all application of microcontroller and which the best microcontroller using to design in arm robot
what is all type of avr atmal mc
Re: avr question
Compared to PIC, the AVR is faster, because its clock is not divided by 4 as in PIC. So 20MHz AVR runs about twice faster, than 40MHz PIC
Re: avr question
The Atmel avr and the Microchip PIC are very similar lines of microcontrollers.
advantages of Atmel avr:
Cost. At the moment, the very lowest-price microcontroller available from any manufacturer is the $0.54 Atmel avr ATtiny11 6 MHz FLASH (same price for 8 pin DIP and 8 pin SOIC)(price in singles from Digikey as of 2004-07-06).
Many Atmel avr µcontrollers, like many Microchip PIC µcontrollers, have a built-in 10 bit ADC.
emaste-sandvine says: "One big advantage of avrs is that they are supported by the GNU Compiler Collection (GCC)."
Disadvantages of Atmel avr:
Single source: only available from Atmel.
Speed: maximum clock rate for Atmel avr is 8 MHz (is that right ?). If you need more processing power, you'll have to switch to a different architecture -- Parallax SX at 50 MHz goes a little faster; some 75 MHz ARM chips are available; if you want more than that in a single chip you'll have to go to microprocessor (Motorola and Intel and Zilog and Transmeta are popular).
Power: Atmel avrs have fairly low power, but the TI MSP430 series has the lowest power of any microcontroller.
Common misperceptions: Some people think the fastest Microchip PIC (20 MHz) is faster than the fastest Atmel avr (8 MHz). They are wrong. (FIXME: what sort of benchmark would be fair ?)
avr question
I dont like microchip mc architecture!
because programmer must beware of memory switch in several banks!
it reduce actual processing power of microcontroller.
Avr is much better. I use both of them and i prefer AVR.
Regards,
Davood.
Re: avr question
Hi Dear ,
AVR can run up to 20Mh not 8 Mhs ! , equal to 20 MIPS , enogh fast for most projects .... ,
of course they are better than PICs ,
and now Atmel has produced AVR-32bit architecture , too fast up tp 133 Mhs , and lowest power consumption .... , you can read more from Atmel website ( www.atmel.com )
Regards ,
hm_fa_da.
avr question
Hi
AVR based on risc architecture and has more optimized instructiond set.
you can use AVR mcu to do simple DSP projects.
regards
