[PIC] TFT LCD graphics generator
akshaybhavsar
Full Member level 2
In my project i am using ILI9488TFT LCD controller.I want to generate graphics.Is there any tool for the same with PIC32mx
thank you
mikroElektronika VisualTFT
It doesnt give me drivers
how to include microelectronics drivers
You didn't mention your Compiler. mikroE VisualTFT works with mikroC PRO PIC32. You design the graphics using VisualTFT and it automatically generates the mikroC, mikrobasic and mikroPascal Codes for mikroC PRO, mikroBasic Pro and mikroPascal Pro for PIC32 or any other mikroE Compilers.
If you want to use it then please confirm if it supports your TFT.
It supports some ILI9xxxx TFTs made by mikroE.
I am using MPLAB ide.i am not using " mikroC PRO PIC32".i am using pic32 with mplab
i want to use MPLAB harmony for the same
ILI9488 is very flexible. Support multi interfaces and color modes. It is depends from application. I think, you will have to write them yourself according your requerements.
I ll try to write..bt how to use MPLAB harmony configurator.How can i assign different pins like data pin,rdx/wrx pins with mplab harmony.
which BSP should i select ?
there are options in harmony like.pin setting and pin diagram..how to use them
