TFT LCD Backlight voltage
ilikebbs
lcd backlight voltage
I have a question about TFT LCD backlight voltage.
I have an inverter. Its kick-off voltage and working voltage is higher than the typical value of LCD.
Can i use it?
Generally i think that higher kick-off voltage is acceptable. I do not know if higher working voltage is acceptable.
Thanks in advance.
rwiggins
Member level 4
backlight voltage
could you use a capacitor to absorb some of the kick-off voltage? what about a resistor to bleed off some of the working voltage?
FANT
Advanced Member level 1
Italy
tft backlight voltage
Usually the voltage for the baclight is around 2000 Vac at high frequency.
So don't touch the wires unless you want an electrizing experience.
Mandi
