Texas Intruments DSP card
peichinlim
Newbie level 6
dsp card models
Hi all,
Currently I'm working with my final year project entitled " design GMSK modulation based on software defined radio (SDR)". And I need to test the program by using DSP card.
Do Texas Intruments DSP card (TMS320) support MatLab language? or any other languages?
Can this DSP card works for the use of testing SDR?
Thank you.:D
regards,
connie
ccs fatal error: could not open source file -i.
Yes MATLAB 7 supports TI DSP Cards with RTW and CCS
fatal error in code composer studio
Hi
In the simulink there is Code Composer Studio links to C2000 & C6000 families.
dsp cards models
YES it cna support, u can find related informaion in ti.com DSP applications
ti dsp cards
Hi
Please concentrate on C laguage for your DSP programing and use Matlab only as a research tool
Kali
matlab code dsp card
Your problem could be solved by using TMS320C6713 DSK and the Code Composer Studio V3.1.
BR
rt_nonfinite.c code composer
hi,
i want to know how to program c6713 dsp for programing? any one do have codes?
-i. ccs fatal error: could not open source file
Matlab supports C6000 and C2000 target processor with its link to Code Composer Studio tool, but you have to check if the release of the tool is compatible with the CCS version you are using (e.g. as far as I know Matlab 7.1 link to CCS tool supports CCS 3.1 but not CCS 3.3). So before starting be sure to check the cross compatibility between the tools by TI and The Mathworks.
Mowgli
texas instruments dsp card +matlab
I am working on SFF SDR Development Platform. Sir i needed a bit of your help.I m lookn fr model of an FM reveiver on system generator for DSP, or any FM demodulator model.
Sir it will really be a great favour from your side.Thanks in advance
Umair Ali
Avionics Dpt
CAE
rtw support for tms320c6713dsk
Sir actually i am lookng for a built model.
could not open source file dsk dsp
fatal error: could not open source file "tmwtypes.h
1 fatal error detected in the compilation of "rt_nonfinite.c".
i m getting thz error while runig simulink model using ccs3.1.
can any body tell me?
source file dsk6713.h
salam!!
how r u?
fatal error: could not open source file "dsk6713.h"
although i ve uplaoded that file.bt it is not executing it.any budy can tell me?
matlab and dsp cards
hello?
i m getting thiz error,
while building the program, even though this header file is included in the project. No error occur, when compiled.
while i m runnig simple square wave program in ccs3.1.
Dear all,
anyone could inform me what dsp series that support for matlab 2010.b and where i have to buy it and how much the price?
thanks all
regards,
lukas - indonesia
