terasic DE0-Nano Developmentkiy- linux help
DNA2683
hi
Im new in the SoC world - im an hardware guy - but i have a software question
I want to buy the terasic DE0-Nano Development kit. but before i do it i have some questions.
i want to work with Linux - terasic give an linux image on SD Card , my software team want to write there code in C# so they use a tool named "MONO" that enable to run C# on Linux.
1. how i can check if the Linux that i get from terasic support "Mono"?
2. we want to work with 4 modules that connected to the USB port ( vis USB HU .The modules work with UART(COM port) - does the Linux that terasic gave have a uart driver ?
thanks
david
you should see de0 document on terasic site. I didn't use de0 but as I know you can install any linux that you want for example ubuntu. these links may help you:
http://hackaday.com/2011/09/27/running-the-linux-kernel-on-a-de0-nano-fpga-board/
thanks for the help
i think i gave a wrong module , there is 2 board
1. DE0-MONO
2. DE0-MONO SoC
i need a information about number 2 DE0-MONO SoC
can you please help me with that? :)
