we are using lm35d sensor to sense temperature,a lcd 16*2 display ,with a change in temperature,we want to change motor speed which drives a fan for cooling .we are using dc 12 v motor.for this we are using fuzzy logic.we dont know how to buid instructions in mickro c language.we dont know how to change speed of motor automatically when temperature changes .,we are using pic 16f877a.
Re: dc motor speed control using fuzzly logic with respect to temperature change in
if u have problem to speed control of dc motor u can use stepper motor because it speed is easily control by increasing/decreasing time delay of the coil sequence energized
e.g
stepper_m=0x08;
delay(10);
stepper_m=0x04;
delay(10);
stepper_m=0x02;
delay(10);
stepper_m=0x01;
delay(10);
P2=0x00;
the speed of stepper motor depend upon delay as given
hi my project is also same using lm35d sensor to sense temperature,a lcd 16*2 display ,with a change in temperature,i want to change motor speed temperature control in the chamber.i am using using dc 24v motor.i dont know how to change speed of motor automatically when temperature changes. i am using AT89C51 microcontroller. i dnt know how to change the speed of motor using microcontroller PWM. plz help me in keil C code and driver circuit for motor
89C51 doesn't have PWM module. You need to write software PWM code. LM35 Temperature value is read by ADC. If your Motor max RPM is 700 and you need to run motor at 600 RPM for cooling if temperature is 50 degree C then you have to convert 50 degrees to PWM duty which gives 600 RPM.
