Temperature “sensor” that works like a fuse
kender
Stanford, SF Bay Peninsula, California, Earth, Sol
sf96e digikey
Colleagues,
Is anyone aware of a small, PCB-mounted (preferably SMT) device that acts like a temperature fuse? Something on the PCB that will break (or may be make) a fusable link if the temperature of the PCB exceeds a threshold temperature somewhere between 40C and 100C? If such exposure takes place, it will be pretty long. I have a suspicion that these devices might be either nontrivial or nonexistent, because they would need to survive the soldering temperatures that are higher than their threshold.
Unfortunately, the arrangements such as thermistor-comparator-flipflop-FET will not work, because the circuit doesn’t have a battery.
I know that there are “permanent” temperature labels that change the color with temperature and retain the color of the maximum temperature (like these https://www.omega.com/toc_asp/subsectionSC.asp?subsection=F02&book=Temperature). But they can’t disable the circuit. They are only visual aids.
Any references, insights or inspiration is appreciated!
Cheers,
Nick
Try searching DigiKey for "thermal cutoff". I've used the Panasonic EYP parts. They are inexpensive axial lead devices, about the size of a 1/2 watt resistor. Other manufacturers and styles probably available. Also known as TCO or thermal link. Commonly used in household appliances to reduce risk of fire in case of overheating.
https://www.digikey.com/
    kender
