tell me a type of relay which can be used
meetbpk
Newbie level 5
chennai
name a type of relay which gets 5v input and turn on 230v AC supply
prmurthy
Full Member level 5
Generally what you get in the market is 12V coil votage, 230VAC. and 5V with 110V. But I think you can use 5V with 110V at 230V with almost half the current rating that is mentioned on the relay. For example 5v 110V 2A you use for 1A 230VAC instead of 110VAC.
Thankyou
Senthilkumar_rjpm
Full Member level 2
chennai
Which load You want to drive from relay? if your load is <5A means you can choose dip realy.. Or < 10A means you go with OEN relay. Or higher amps means choose high amps relay... This links may usefull to u...
https://www.azettler.com/pdfs/az822.pdf
Google Image Result for http://images.components.omron.eu/OCB/Products/Relays/PCB%20Power%20Relays/Up%20to%2010A/G5LA/images/G5LA400x400.jpg
Google Image Result for http://images.gasgoo.com/MiMgIzM2ODQ2MzEwMA--/auto-part-12v-24v-30a-40a-universal-automotive-relay.jpg
meetbpk
Newbie level 5
chennai
i am going to drive inductive load(ceiling fan).
Senthilkumar_rjpm
Full Member level 2
chennai
Well you can use this relay (Link) or equvalant which is available near to u...
Google Image Result for **broken link removed**
