TCP/IP - registers of the UMC and Realtek - are they similar
D1_DRE
Member level 3
Member level 3
TCP/IP
Hello,
I'll appreciate if you can help me out here. I'm an electrical and electronic eng student and I'm demostrating simple I/O via ethernet for my final year project. I noticed you are knowledgable in that field. In most projects I've seen around the web, most implementation was with a Realtek ethernet chipset which is NE2000 compatible. However, I was supplied with an UMC ethernet chip (UM9007AF) ISA CARD also NE2000 compliant. Here is my question. Can I assume the internal registers of the UMC and Realtek are similar or how do I go about, interfacing with this ISA NIC because I do not have the datasheet for the UMC chip but have a great wealth of info on the Realtek chipset.
Thanks for your time
Dre
