Hi
I have made my own board using W5500 IC. I set the W5500 to work in TCP Server. I can correctly Configure any registers of W5500 by SPI Interface. After setting W5500 in TCP server and get it on listen mode, when i try to connect it using hercules software, i can't connect correctly and i face with this:
can any one help me to find out problem?
It would help to clarify a bit if you also inform how your local network is configured (DHCP, proxy, DNS, etc ...). Did you try seeing what appear at any network tool, eg IPCONFIG on Windows ?
