task for drawing circuits
ilysselk999
Newbie
Newbie level 1
Can anyone help me with this task plz
From the physical point of view, an alarm loop (AL) is an electrical circuit that connects the device with detectors (sensors) using wired connections. The main task of the alarm loop is to ensure the detection of the fact of detector actuation. The loop is connected to the resistance meter via the terminals located on the control panel board. The microprocessor measures the electrical resistance of the entire loop circuit and, based on its value, decides whether the detector has been triggered or not.
Any detector can be represented as an electrical contact, which, when triggered, changes its resistance dramatically: it becomes either closed (contact resistance is zero (NC)) or open (contact resistance is infinity (NO)).
From the physical point of view, each loop has different variants of wiring diagrams, which the user selects. The wiring diagram depicts the detector contacts, resistors, and other components that ensure the operation of the alarm loop.
Main task:
It is necessary to depict an electrical ring/chain (as in the connection example) on which there will be 2 loops (loops/sensors/keys) with the correct type of connection (series and parallel) and understand when we have a change in the circuit, namely, whether there is a current when any of the loops (loops/sensors/keys) is triggered
Image of the loop connection:
1. with 2 normally open (NO) sensors. By default, the current does NOT flow through the circuit, and when triggered (closed), it does
2. with 2 normally closed (NC) detectors. By default, the current flows in a circuit, and when triggered (opened), it does NOT flow
3. with mixed contact activation, where there are normally closed (NC) and normally open (NO) sensors
4. with 2 normally closed (NC) sensors and a 5 kΩ resistor (the circuit resistance is also 5 kΩ)
5. with 2 normally open (NO) sensors and a 5 kΩ resistor (the circuit resistance is also 5 kΩ)
The resistor is used to prevent sabotage because if the circuit to the loops/sensors is shorted, then the triggering will not be detected. The resistor must be placed in such a way that we can understand when the circuit is shorted to the loop/sensor (resistance does not correspond to the expected value (resistor value))
I have to draw the serie version and the parallel respecting the example in picture plz can anyone help me do that Im new in electronic
Main task:
I have to draw the serie version and the parallel respecting the example given plz can anyone help me do that Im new in electronic
first of all: We won´t do your job.
We will help you. But for this we have to understand what´s the exact problem is. --> Please tell exactly why you think you can´t draw them on your own.
It shouldn´t be that difficult to draw a couple of switches in parallel and in series accordingly.
It seems you spent time to ask AI for assistance.
But you could also do a standard internet search for "NC alarm circuit" and "NO alarm circuit", or "how to wire multiple NC alarm" ... or similar.
For sure there come up a lot of unsuitable pictures ... but it should be no problem for you to select the right ones.
Klaus
I imagine that this homework assignment followed
some course of instruction or reading, that meant
to deliver the knowledge required, but which has
been skated around?
Series, parallel, open, closed are basic concepts
that are probably the whole point.
LaTeX Commands Quick-Menu:
