Boosted67
Junior Member level 1
See if I can explain this correctly.
We are trying to take a 12v signal and reduce its rpm.
The sensor is magnetic. The sensor is fed 12v, a metal wheel w teeth evenly spaced rotates near the sensor and the tooth triggers a pulse. The pulsing is sent out and read. What we'd like to essentially do is have let's say 1000 pulses per minute, and convert it to 800 pulses. Tried to look into it a bit, and came across a capacitor. But not sure if that be useful in this context.
The pulses will constantly vary as well. So so the relationship between input and output can vary as the pulse per minute change. But needs to be consistent.
Any direction would be fantastic
