silic
Newbie level 5
tafe programmer
I try to program a 2051 using TAFE programmer(http://www.ic-prog.com/2051pv2.gif) and ic-prog.exe and it doesnt work to me..
1) these connections must be done;--->89c2051 pin20(+5v), pin10(GND), 74hc174 pin16(+5v) pin8(GND)
Because they don't exist in the 2051pv2.gif of TAFE programmer...:/
2) I measured around 12V at pin 14 of parallel port which i think is sufficient to blow its input buffer IC.Is this correct;Can i put a diode(1N4001) to isolate pin14 of 12volt;
3)does anyone knows the settings in the ic-prog with TAFE programmer;
sorry for my english!
