Dec 16, 2009 #1 R ragtap Newbie level 2 Joined Dec 16, 2009 Messages 2 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location uK Activity points 1,291 Hi All I know this might be posted before but i really cannot find what im looking for! I´m trying to do a proyect in C18 using one LCD based on a T6963, but i cant find a libraRy for C18! Does anyone knows were can i find it? Thanx a lot in advance!
Dec 16, 2009 #2 M miredox Member level 4 Joined Oct 21, 2009 Messages 76 Helped 9 Reputation 18 Reaction score 4 Trophy points 1,288 Activity points 1,791 Its not the most used LCD driver, but if you look around on google, you will find several libraries for different kind of microcontrollers. For example for PIC16F: http://www.njqrp.org/ham-pic/T6963LCD.c or for avr: http://en.radzio.dxp.pl/t6963/ Since these are written in C, and you also use C, it should be easy to port these libraries to your application. In the best case, you will only need to change the port declarations.
Dec 16, 2009 #3 R ragtap Newbie level 2 Joined Dec 16, 2009 Messages 2 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location uK Activity points 1,291 Thanx for the information. Even is not the most common, it should be common enough as for people could have developed a library... i think!
