SystemVerilog simulation in Questasim 6.2b ?
subos
Newbie level 5
questasim 6.2b systemverilog
The following warning is reported.
Some checking for conflicts with continuous assignments to variables not yet supported. Run vopt to provide additional design-level checks.
It can be seen clearly in the technotes that QuestaSim6.2b supports "continuous assignments to variables". Why does it report the above warning?
systemverilog svchk
Can you send the file which gives you this warning .. ?
[svchk] - some checking for conflicts
Thanks for your reply.
The following is the source file. I download it from an open-core website.
* (C)2007 Robert Mullins
* Computer Architecture Group, Computer Laboratory
* University of Cambridge, UK.
* Pipelined channel (link) between routers
* 'stages' may range from 0 (routers are clocked but link is simply a wire)
* to N
module NW_pipelined_channel (data_in, data_out, clk, rst_n);
parameter type reg_t = flit_t;
parameter stages = 4;
input reg_t data_in;
output reg_t data_out;
input clk, rst_n;
genvar st;
reg_t ch_reg[stages-1:0];
generate
if (stages==0) begin
// no registers in channel
assign data_out = data_in;
end else begin
for (st=0; st<stages; st++) begin:eachstage
if (st==0) begin
// first register in channel
NW_reg #(.reg_t(flit_t)) rg (.data_in(data_in), .data_out(ch_reg[0]), .clk, .rst_n);
end else begin
// other registers
NW_reg #(.reg_t(flit_t)) rg (.data_in(ch_reg[st-1]), .data_out(ch_reg[st]), .clk, .rst_n);
end
end
assign data_out = ch_reg[stages-1];
end
endgenerate
endmodule // NW_pipelined_channel
The related warnings are shown below:
# ** Warning: lib/NW_pipelined_channel.v(31): [SVCHK] - Some checking for conflicts with continuous assignments to variables not yet supported. Run vopt to provide additional design-level checks.
# ** Warning: lib/NW_pipelined_channel.v(43): [SVCHK] - Some checking for conflicts with continuous assignments to variables not yet supported. Run vopt to provide additional design-level checks.
these features are only supported in questasim.
What i figured that you get this message only if the continuous assignments are inside a generate block.
However, when i ran a simulation the results were ok.
    subos
systemverilog questasim
Thanks for your help.
So, I can omit these warnings.
