Register Log in
Systemverilog function output vs returned value
shaiko
Advanced Member level 5
Hello,
I came across this Systemverilog code online:
function mul (input int x, y, output int z);
z = x*y + 1;
return x * y;
endfunction
As you can see - it outputs the integer 'z' and at the same time returns x*y.
Questions:
1.How can we call the function to get the value of 'z' ?
2.What's the purpose/use case of having an output and a return value.
FvM
Super Moderator
Staff member
Bochum, Germany
System verilog functions can have output and inout arguments as they are used for tasks. They can have zero, one or multiple output values, with various purposes.
You get the value by using a variable as actual argument.
    shaiko
dave_59
Advanced Member level 3
Fremont, CA, USA
SystemVerilog makes a distinction between subroutines that may consume time (tasks) and those that must not (functions). If you want to use a subroutine as part of an expression, you must use a non-time consuming function that returns a single value. If you have a subroutine that guarantees it won't consume time, use a function.
Tasks are called like a statement and do not return a value. You can use output arguments to pass out values since unlike C/C++, there are no pointers that you could pass in as a reference. (although class handles as an argument work like a passed reference).
Sometimes you need a function to output more than one value. Here the function returns a status indicating success or failure. This leaves the output arugment element free to return any value.
Code Verilog - [expand]
8
9
10
11
12
13
14
int AA[string];
int arg;
function bit lookup(input string key, output int element);
  if (AA.exists(key) ) begin
        element = AA[key[;
       return 1;
  else return 0;
endfunction
if (lookup("mode", arg))
    $display("Found mode : %d", arg)l
else
   $error("Didn't find 'mode');
    shaiko
shaiko
Thanks dave_59.
But isn't the scope of "element" local to the function?
How do we get the value of "element" outside of the function.
For example:
suppose we have a signal named: "some_signal". What's the syntax to assign it the value of "element" ?
dave_59
Fremont, CA, USA
Change arg to some_signal in my example.
This a very basic part of Verilog. It's all explained in section 13.5 Subroutine calls and argument passing in the IEEE 1800-2017 LRM, and in many online examples
Reactions: shaiko
    shaiko
Toggle Sidebar
Design Fast
