SystemVerilog Calling Random Functions
forkconfig
Member level 1
Member level 1
I am trying to test a simple fifo design and would like to call various tasks (push, pop, pushpop) randomly.
How can I do that?
I'm new to Verilog and SV so please bear that in mind in the explanation.
Thanks
I want to take my question 1 step further. What if I want to add constraints?
Going back to my example, if I have a fifo and I want to randomize pushes, pops, and push_pops, however, I also want to ensure that I never pop when the fifo is empty?
I looked around online and found "constraint gaurds". But I was wondering if you could please check the sample code I made bellow and tell me if I'm understanding things right:
randcase
20 : push(data);
10 : constraint { if( fifo_io.cb.empty != null ) pop() } ;
50 : push_pop(data)
endcase
randsequence( main )
main : push := 20| pop := 10| push_pop := 50;
push: push(data);
pop: constraint { if( fifo_io.cb.empty != null ) pop() } ;
push_pop: push_pop(data);
endsequence
How does that look?
You cannot use constraints with these constructs - they are only for the built-in randomize() method. However, you can dynamically modify the weights; a weight of zero means that branch will not be taken.
randcase
  20 : push(data);
  10*(fifo_io.cb.empty != null ) : pop();
  50 : push_pop(data);
endcase
  main : push := 20| pop := (10*(fifo_io.cb.empty != null ))| push_pop := 50;
  push: push(data);
  pop: pop();
endsequence
There are a few other things you could do with the randsequence, like if-else productions, but I'll leave that as an exercise.
