Hi fellows,
I am quite familiar with writing embedded Software using C and I experienced in describing Hardware using VHDL but I have never used SystemC, this is why I ask what it is good for. (serious - no flamewar intended)
AFAIK SystemC is intended for high level simulation of complex systems with hard- and software where the hardware is discribed in an abstract form (maybe notsynthesizable). How it actually works I don't know - Do I need a SystemC model of the processor my software will run on?
I heard a guy who claimed he described/programmed a module of the system and then can compile it to a netlist for FPGA or just as regular binary code for the CPU. This way the design space can be explored and decided later if a component will be run on CPU or is implemented as hardware. - Is this possible????
I doubt it really works that way - modeling hardware (in an efficient way) is really different from programming software. If this all becomes the same and systemC compilers are that good - what do we still use HDL.
yours truly
thomas
