Systemc install error (Help)
tito20065
Newbie level 2
Newbie level 2
Hi everybody,
I know most people have faced same problem. After extensive search and trying various options i am putting a request here.
i trying to install systemc-2.2.0 by using OS(Ubuntu) but i can't
when i try "" make install "" i get the following error
and that what happen
PHP:
Making install in src
make[1]: Entering directory `/home/systemc-2.3.0/src'
Making install in sysc
make[2]: Entering directory `/home/systemc-2.3.0/src/sysc'
Making install in kernel
make[3]: Entering directory `/home/systemc-2.3.0/src/sysc/kernel'
make[4]: Entering directory `/home/systemc-2.3.0/src/sysc/kernel'
make[4]: Nothing to be done for `install-exec-am'.
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/sysc/kernel
for file in sc_attribute.h sc_boost.h sc_cmnhdr.h sc_constants.h sc_cor.h sc_dynamic_processes.h sc_event.h sc_except.h sc_externs.h sc_join.h sc_kernel_ids.h sc_macros.h sc_module.h sc_module_name.h sc_object.h sc_process.h sc_process_handle.h sc_reset.h sc_runnable.h sc_sensitive.h sc_spawn.h sc_spawn_options.h sc_simcontext.h sc_time.h sc_ver.h sc_wait.h sc_wait_cthread.h ; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/kernel/$file; \
	done
make[4]: Leaving directory `/home/systemc-2.3.0/src/sysc/kernel'
make[3]: Leaving directory `/home/systemc-2.3.0/src/sysc/kernel'
Making install in qt
make[3]: Entering directory `/home/systemc-2.3.0/src/sysc/qt'
make[4]: Entering directory `/home/systemc-2.3.0/src/sysc/qt'
make[4]: Leaving directory `/home/systemc-2.3.0/src/sysc/qt'
make[3]: Leaving directory `/home/systemc-2.3.0/src/sysc/qt'
Making install in communication
make[3]: Entering directory `/home/systemc-2.3.0/src/sysc/communication'
make[4]: Entering directory `/home/systemc-2.3.0/src/sysc/communication'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/sysc/communication
for file in sc_buffer.h sc_clock.h sc_clock_ports.h sc_communication_ids.h sc_event_finder.h sc_event_queue.h sc_export.h sc_fifo.h sc_fifo_ifs.h sc_fifo_ports.h sc_host_mutex.h sc_interface.h sc_mutex.h sc_mutex_if.h sc_port.h sc_prim_channel.h sc_semaphore.h sc_semaphore_if.h sc_signal.h sc_signal_ifs.h sc_signal_ports.h sc_signal_resolved.h sc_signal_resolved_ports.h sc_signal_rv.h sc_signal_rv_ports.h sc_writer_policy.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/communication/$file; \
	done
make[4]: Leaving directory `/home/systemc-2.3.0/src/sysc/communication'
make[3]: Leaving directory `/home/systemc-2.3.0/src/sysc/communication'
Making install in tracing
make[3]: Entering directory `/home/systemc-2.3.0/src/sysc/tracing'
make[4]: Entering directory `/home/systemc-2.3.0/src/sysc/tracing'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/sysc/tracing
for file in sc_trace.h sc_vcd_trace.h sc_wif_trace.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/tracing/$file; \
	done
make[4]: Leaving directory `/home/systemc-2.3.0/src/sysc/tracing'
make[3]: Leaving directory `/home/systemc-2.3.0/src/sysc/tracing'
Making install in utils
make[3]: Entering directory `/home/systemc-2.3.0/src/sysc/utils'
make[4]: Entering directory `/home/systemc-2.3.0/src/sysc/utils'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/sysc/utils
for file in sc_hash.h sc_iostream.h sc_list.h sc_machine.h sc_mempool.h sc_pq.h sc_pvector.h sc_report.h sc_report_handler.h sc_string.h sc_temporary.h sc_utils_ids.h sc_vector.h ; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/utils/$file; \
	done
make[4]: Leaving directory `/home/systemc-2.3.0/src/sysc/utils'
make[3]: Leaving directory `/home/systemc-2.3.0/src/sysc/utils'
Making install in packages
make[3]: Entering directory `/home/systemc-2.3.0/src/sysc/packages'
Making install in boost
make[4]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost'
Making install in bind
make[5]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/bind'
make[6]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/bind'
make[7]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/bind'
make[7]: Nothing to be done for `install-exec-am'.
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/sysc/packages/boost/bind
for file in apply.hpp arg.hpp bind_cc.hpp bind_mf_cc.hpp bind_template.hpp make_adaptable.hpp mem_fn_cc.hpp mem_fn_template.hpp mem_fn_vw.hpp placeholders.hpp protect.hpp; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/packages/boost/bind/$file; \
	done
make[7]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/bind'
make[6]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/bind'
make[5]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/bind'
Making install in config
make[5]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/config'
Making install in compiler
make[6]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/config/compiler'
make[7]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/config/compiler'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/sysc/packages/boost/config/compiler
for file in borland.hpp comeau.hpp common_edg.hpp compaq_cxx.hpp digitalmars.hpp gcc.hpp greenhills.hpp hp_acc.hpp intel.hpp kai.hpp metrowerks.hpp mpw.hpp sgi_mipspro.hpp sunpro_cc.hpp vacpp.hpp visualc.hpp; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/packages/boost/config/compiler/$file; \
	done
make[7]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/config/compiler'
make[6]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/config/compiler'
Making install in platform
make[6]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/config/platform'
make[7]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/config/platform'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/sysc/packages/boost/config/platform
for file in aix.hpp amigaos.hpp beos.hpp bsd.hpp cygwin.hpp hpux.hpp irix.hpp linux.hpp macos.hpp solaris.hpp win32.hpp; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/packages/boost/config/platform/$file; \
	done
make[7]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/config/platform'
make[6]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/config/platform'
Making install in stdlib
make[6]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/config/stdlib'
make[7]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/config/stdlib'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/sysc/packages/boost/config/stdlib
for file in dinkumware.hpp libcomo.hpp libstdcpp3.hpp modena.hpp msl.hpp roguewave.hpp sgi.hpp stlport.hpp vacpp.hpp; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/packages/boost/config/stdlib/$file; \
	done
make[7]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/config/stdlib'
make[6]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/config/stdlib'
Making install in .
make[6]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/config'
make[7]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/config'
for file in posix_features.hpp select_compiler_config.hpp select_platform_config.hpp select_stdlib_config.hpp suffix.hpp user.hpp; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/packages/boost/config/$file; \
	done
make[7]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/config'
make[6]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/config'
make[5]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/config'
Making install in detail
make[5]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/detail'
make[6]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/detail'
make[6]: Nothing to be done for `install-exec-am'.
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/sysc/packages/boost/detail
for file in endian.hpp workaround.hpp ; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/packages/boost/detail/$file; \
	done
make[6]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/detail'
make[5]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/detail'
Making install in mpl
make[5]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/mpl'
Making install in aux_
make[6]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/mpl/aux_'
make[7]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/mpl/aux_/config'
make[8]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/mpl/aux_/config'
make[8]: Nothing to be done for `install-exec-am'.
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/sysc/packages/boost/mpl/aux_/config
for file in adl.hpp gcc.hpp intel.hpp msvc.hpp static_constant.hpp workaround.hpp; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/packages/boost/mpl/aux_/config/$file; \
	done
make[8]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/mpl/aux_/config'
make[7]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/mpl/aux_/config'
Making install in .
make[7]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/mpl/aux_'
make[8]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/mpl/aux_'
for file in adl_barrier.hpp; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/packages/boost/mpl/aux_/$file; \
	done
make[8]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/mpl/aux_'
make[7]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/mpl/aux_'
make[6]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/mpl/aux_'
Making install in .
make[6]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/mpl'
make[7]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/mpl'
for file in bool.hpp bool_fwd.hpp integral_c_tag.hpp ; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/packages/boost/mpl/$file; \
	done
make[7]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/mpl'
make[6]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/mpl'
make[5]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/mpl'
Making install in utility
make[5]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/utility'
make[6]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost/utility'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/sysc/packages/boost/utility
for file in addressof.hpp enable_if.hpp; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/packages/boost/utility/$file; \
	done
make[6]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/utility'
make[5]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost/utility'
Making install in .
make[5]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost'
make[6]: Entering directory `/home/systemc-2.3.0/src/sysc/packages/boost'
for file in bind.hpp config.hpp get_pointer.hpp mem_fn.hpp non_type.hpp ref.hpp type.hpp; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/packages/boost/$file; \
	done
make[6]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost'
make[5]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost'
make[4]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages/boost'
Making install in .
make[4]: Entering directory `/home/systemc-2.3.0/src/sysc/packages'
make[5]: Entering directory `/home/systemc-2.3.0/src/sysc/packages'
make[5]: Nothing to be done for `install-exec-am'.
make[5]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages'
make[4]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages'
make[3]: Leaving directory `/home/systemc-2.3.0/src/sysc/packages'
Making install in datatypes
make[3]: Entering directory `/home/systemc-2.3.0/src/sysc/datatypes'
Making install in bit
make[4]: Entering directory `/home/systemc-2.3.0/src/sysc/datatypes/bit'
make[5]: Entering directory `/home/systemc-2.3.0/src/sysc/datatypes/bit'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/sysc/datatypes/bit
for file in sc_bit.h sc_bit_ids.h sc_bit_proxies.h sc_bv.h sc_bv_base.h sc_logic.h sc_lv.h sc_lv_base.h sc_proxy.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/datatypes/bit/$file; \
	done
make[5]: Leaving directory `/home/systemc-2.3.0/src/sysc/datatypes/bit'
make[4]: Leaving directory `/home/systemc-2.3.0/src/sysc/datatypes/bit'
Making install in fx
make[4]: Entering directory `/home/systemc-2.3.0/src/sysc/datatypes/fx'
make[5]: Entering directory `/home/systemc-2.3.0/src/sysc/datatypes/fx'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/sysc/datatypes/fx
for file in fx.h sc_context.h sc_fix.h sc_fixed.h sc_fx_ids.h sc_fxcast_switch.h sc_fxdefs.h sc_fxnum.h sc_fxnum_observer.h sc_fxtype_params.h sc_fxval.h sc_fxval_observer.h sc_ufix.h sc_ufixed.h scfx_ieee.h scfx_mant.h scfx_other_defs.h scfx_params.h scfx_rep.h scfx_string.h scfx_utils.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/datatypes/fx/$file; \
	done
make[5]: Leaving directory `/home/systemc-2.3.0/src/sysc/datatypes/fx'
make[4]: Leaving directory `/home/systemc-2.3.0/src/sysc/datatypes/fx'
Making install in int
make[4]: Entering directory `/home/systemc-2.3.0/src/sysc/datatypes/int'
make[5]: Entering directory `/home/systemc-2.3.0/src/sysc/datatypes/int'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/sysc/datatypes/int
for file in sc_bigint.h sc_biguint.h sc_int.h sc_int_base.h sc_int_ids.h sc_length_param.h sc_nbdefs.h sc_nbexterns.h sc_nbutils.h sc_signed.h sc_uint.h sc_uint_base.h sc_unsigned.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/datatypes/int/$file; \
	done
make[5]: Leaving directory `/home/systemc-2.3.0/src/sysc/datatypes/int'
make[4]: Leaving directory `/home/systemc-2.3.0/src/sysc/datatypes/int'
Making install in misc
make[4]: Entering directory `/home/systemc-2.3.0/src/sysc/datatypes/misc'
make[5]: Entering directory `/home/systemc-2.3.0/src/sysc/datatypes/misc'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/sysc/datatypes/misc
for file in sc_concatref.h sc_value_base.h ; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/sysc/datatypes/misc/$file; \
	done
make[5]: Leaving directory `/home/systemc-2.3.0/src/sysc/datatypes/misc'
make[4]: Leaving directory `/home/systemc-2.3.0/src/sysc/datatypes/misc'
Making install in .
make[4]: Entering directory `/home/systemc-2.3.0/src/sysc/datatypes'
make[5]: Entering directory `/home/systemc-2.3.0/src/sysc/datatypes'
make[5]: Leaving directory `/home/systemc-2.3.0/src/sysc/datatypes'
make[4]: Leaving directory `/home/systemc-2.3.0/src/sysc/datatypes'
make[3]: Leaving directory `/home/systemc-2.3.0/src/sysc/datatypes'
Making install in .
make[3]: Entering directory `/home/systemc-2.3.0/src/sysc'
make[4]: Entering directory `/home/systemc-2.3.0/src/sysc'
test -z "/home/systemc-2.3.0/lib-linux64" || /bin/mkdir -p "/home/systemc-2.3.0/lib-linux64"
 /bin/sh ../../libtool --mode=install /usr/bin/install -c  'libsystemc.la' '/home/systemc-2.3.0/lib-linux64/libsystemc.la'
libtool: install: /usr/bin/install -c .libs/libsystemc-2.3.0.so /home/systemc-2.3.0/lib-linux64/libsystemc-2.3.0.so
libtool: install: (cd /home/systemc-2.3.0/lib-linux64 && { ln -s -f libsystemc-2.3.0.so libsystemc.so || { rm -f libsystemc.so && ln -s libsystemc-2.3.0.so libsystemc.so; }; })
libtool: install: /usr/bin/install -c .libs/libsystemc.lai /home/systemc-2.3.0/lib-linux64/libsystemc.la
libtool: install: /usr/bin/install -c .libs/libsystemc.a /home/systemc-2.3.0/lib-linux64/libsystemc.a
libtool: install: chmod 644 /home/systemc-2.3.0/lib-linux64/libsystemc.a
libtool: install: ranlib /home/systemc-2.3.0/lib-linux64/libsystemc.a
libtool: finish: PATH="/sbin:/bin:/usr/sbin:/usr/bin:/sbin" ldconfig -n /home/systemc-2.3.0/lib-linux64
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
     during execution
   - add LIBDIR to the `LD_RUN_PATH' environment variable
     during linking
   - use the `-Wl,-rpath -Wl,LIBDIR' linker flag
   - have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
for file in ; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/$file; \
	done
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/lib-linux64
/usr/bin/install -c -m 644 libsystemc.la \
make[4]: Leaving directory `/home/systemc-2.3.0/src/sysc'
make[3]: Leaving directory `/home/systemc-2.3.0/src/sysc'
make[2]: Leaving directory `/home/systemc-2.3.0/src/sysc'
Making install in tlm_core/tlm_1
make[2]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1'
Making install in tlm_analysis
make[3]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_analysis'
make[4]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_analysis'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/tlm_core/tlm_1/tlm_analysis
for file in tlm_analysis_fifo.h tlm_analysis.h tlm_analysis_if.h tlm_analysis_port.h tlm_analysis_triple.h tlm_write_if.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/tlm_core/tlm_1/tlm_analysis/$file; \
	done
make[4]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_analysis'
make[3]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_analysis'
Making install in tlm_req_rsp
make[3]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp'
Making install in tlm_adapters
make[4]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_adapters'
make[5]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_adapters'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/tlm_core/tlm_1/tlm_req_rsp/tlm_adapters
for file in tlm_adapters.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/tlm_core/tlm_1/tlm_req_rsp/tlm_adapters/$file; \
	done
make[5]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_adapters'
make[4]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_adapters'
Making install in tlm_ports
make[4]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_ports'
make[5]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_ports'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/tlm_core/tlm_1/tlm_req_rsp/tlm_ports
for file in tlm_event_finder.h tlm_nonblocking_port.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/tlm_core/tlm_1/tlm_req_rsp/tlm_ports/$file; \
	done
make[5]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_ports'
make[4]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_ports'
Making install in tlm_1_interfaces
make[4]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_1_interfaces'
make[5]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_1_interfaces'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/tlm_core/tlm_1/tlm_req_rsp/tlm_1_interfaces
for file in tlm_core_ifs.h tlm_fifo_ifs.h tlm_master_slave_ifs.h tlm_tag.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/tlm_core/tlm_1/tlm_req_rsp/tlm_1_interfaces/$file; \
	done
make[5]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_1_interfaces'
make[4]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_1_interfaces'
Making install in tlm_channels
make[4]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_channels'
Making install in tlm_fifo
make[5]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_channels/tlm_fifo'
make[6]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_channels/tlm_fifo'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/tlm_core/tlm_1/tlm_req_rsp/tlm_channels/tlm_fifo
for file in circular_buffer.h tlm_fifo.h tlm_fifo_peek.h tlm_fifo_put_get.h tlm_fifo_resize.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/tlm_core/tlm_1/tlm_req_rsp/tlm_channels/tlm_fifo/$file; \
	done
make[6]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_channels/tlm_fifo'
make[5]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_channels/tlm_fifo'
Making install in tlm_req_rsp_channels
make[5]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_channels/tlm_req_rsp_channels'
make[6]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_channels/tlm_req_rsp_channels'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/tlm_core/tlm_1/tlm_req_rsp/tlm_channels/tlm_req_rsp_channels
for file in tlm_put_get_imp.h tlm_req_rsp_channels.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/tlm_core/tlm_1/tlm_req_rsp/tlm_channels/tlm_req_rsp_channels/$file; \
	done
make[6]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_channels/tlm_req_rsp_channels'
make[5]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_channels/tlm_req_rsp_channels'
Making install in .
make[5]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_channels'
make[6]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_channels'
make[6]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_channels'
make[5]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_channels'
make[4]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp/tlm_channels'
Making install in .
make[4]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp'
make[5]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp'
for file in tlm_req_rsp.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/tlm_core/tlm_1/tlm_req_rsp/$file; \
	done
make[5]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp'
make[4]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp'
make[3]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1/tlm_req_rsp'
Making install in .
make[3]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1'
make[4]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_1'
make[4]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1'
make[3]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1'
make[2]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_1'
Making install in tlm_core/tlm_2
make[2]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_2'
Making install in tlm_2_interfaces
make[3]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_2/tlm_2_interfaces'
make[4]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_2/tlm_2_interfaces'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/tlm_core/tlm_2/tlm_2_interfaces
for file in tlm_2_interfaces.h tlm_dmi.h tlm_fw_bw_ifs.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/tlm_core/tlm_2/tlm_2_interfaces/$file; \
	done
make[4]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_2/tlm_2_interfaces'
make[3]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_2/tlm_2_interfaces'
Making install in tlm_quantum
make[3]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_2/tlm_quantum'
make[4]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_2/tlm_quantum'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/tlm_core/tlm_2/tlm_quantum
for file in tlm_global_quantum.h tlm_quantum.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/tlm_core/tlm_2/tlm_quantum/$file; \
	done
make[4]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_2/tlm_quantum'
make[3]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_2/tlm_quantum'
Making install in tlm_generic_payload
make[3]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_2/tlm_generic_payload'
make[4]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_2/tlm_generic_payload'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/tlm_core/tlm_2/tlm_generic_payload
for file in tlm_array.h tlm_endian_conv.h tlm_generic_payload.h tlm_gp.h tlm_helpers.h tlm_phase.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/tlm_core/tlm_2/tlm_generic_payload/$file; \
	done
make[4]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_2/tlm_generic_payload'
make[3]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_2/tlm_generic_payload'
Making install in tlm_sockets
make[3]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_2/tlm_sockets'
make[4]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_2/tlm_sockets'
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/tlm_core/tlm_2/tlm_sockets
for file in tlm_initiator_socket.h tlm_sockets.h tlm_target_socket.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/tlm_core/tlm_2/tlm_sockets/$file; \
	done
make[4]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_2/tlm_sockets'
make[3]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_2/tlm_sockets'
Making install in .
make[3]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_2'
make[4]: Entering directory `/home/systemc-2.3.0/src/tlm_core/tlm_2'
for file in tlm_version.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/tlm_core/tlm_2/$file; \
	done
make[4]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_2'
make[3]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_2'
make[2]: Leaving directory `/home/systemc-2.3.0/src/tlm_core/tlm_2'
Making install in tlm_utils
make[2]: Entering directory `/home/systemc-2.3.0/src/tlm_utils'
make[3]: Entering directory `/home/systemc-2.3.0/src/tlm_utils'
make[3]: Nothing to be done for `install-exec-am'.
/bin/sh /home/systemc-2.3.0/config/install-sh -d /home/systemc-2.3.0/include/tlm_utils
for file in instance_specific_extensions.h multi_passthrough_initiator_socket.h multi_passthrough_target_socket.h multi_socket_bases.h passthrough_target_socket.h peq_with_cb_and_phase.h peq_with_get.h simple_initiator_socket.h simple_target_socket.h tlm_quantumkeeper.h; do \
	  /usr/bin/install -c -m 644 ./$file /home/systemc-2.3.0/include/tlm_utils/$file; \
	done
make[3]: Leaving directory `/home/systemc-2.3.0/src/tlm_utils'
make[2]: Leaving directory `/home/systemc-2.3.0/src/tlm_utils'
Making install in .
make[2]: Entering directory `/home/systemc-2.3.0/src'
make[3]: Entering directory `/home/systemc-2.3.0/src'
for file in systemc systemc.h tlm tlm.h; do \
        done
make[3]: Leaving directory `/home/systemc-2.3.0/src'
make[2]: Leaving directory `/home/systemc-2.3.0/src'
make[1]: Leaving directory `/home/systemc-2.3.0/src'
Making install in examples
make[1]: Entering directory `/home/systemc-2.3.0/examples'
make[2]: Entering directory `/home/systemc-2.3.0/examples/sysc'
Making install in fft
make[3]: Entering directory `/home/systemc-2.3.0/examples/sysc/fft'
Making install in fft_flpt
make[4]: Entering directory `/home/systemc-2.3.0/examples/sysc/fft/fft_flpt'
make[5]: Entering directory `/home/systemc-2.3.0/examples/sysc/fft/fft_flpt'
/bin/sh /home/systemc-2.3.0/config/install-sh -d .
for file in in_imag in_imag.1 in_imag.2 in_imag.3 in_imag.4 in_real in_real.1 in_real.2 in_real.3 in_real.4 out_imag.1.golden out_imag.2.golden out_imag.3.golden out_imag.4.golden out_real.1.golden out_real.2.golden out_real.3.golden out_real.4.golden  fft.cpp main.cpp sink.cpp source.cpp fft.h sink.h source.h; do \
		/usr/bin/install -c -m 644 ./$file ./$file; \
	done
make[5]: Leaving directory `/home/systemc-2.3.0/examples/sysc/fft/fft_flpt'
make[4]: Leaving directory `/home/systemc-2.3.0/examples/sysc/fft/fft_flpt'
make[3]: Leaving directory `/home/systemc-2.3.0/examples/sysc/fft'
make[2]: Leaving directory `/home/systemc-2.3.0/examples/sysc'
make[1]: Leaving directory `/home/systemc-2.3.0/examples'
i hope you can help
Good thing I asked you to put in more details.
Because your screenshot is NOT the same type of install as the longer more meaningful output. In fact, as an exercise ... can you point us to the error message in the quote? Because that looks like a succesful make install.
Put another way: did you actually test it AGAIN after the latest make install? Because the result is totally different.
And please next time just post stuff straight away instead of PMing me. :p
On Ubutnu Systems, you should do a "sudo ./configure" , "sudo make" and "sudo make install". This will give the compiler and maker superuser permissions and complete the install.
Except for all the instances where this is not the magic cure. If you check the first post you'll see that it is the install run as root that goes *urgle*, and it was the install as non-root that succeeded.
And given the lack of further reply from tito20065 I guess it is working and he can't be bothered to follow up in the interest of future posters that might run into a similar problem. Or it didn't work and he hurled himself of a cliff like a depressed lemming.
