[SOLVED] System Verilog conditional parameter
shparekh
Newbie
Newbie level 3
I have a following statement in my code -
genvar sliteIfIter_grp1
generate for (  sliteIfIter_grp1=0;
                  sliteIfIter_grp1<MAX_SLITE_GRP1;
                  sliteIfIter_grp1+=1)
The psuedo code to assign MAX_SLITE_GRP1 is
 if (SLITE_NUM > 4)
   localparam MAX_SLITE_GRP1 = 4
 else
   localparam MAX_SLITE_GRP1 = SLITE_NUM
SLITE_NUM is a parameter which can be overridden at the time instantiating the block.
Can you please suggest how I can write this in system verilog?
Thanks.
Best regards,
SP
localparam MAX_SLITE_GRP1 = (SLITE_NUM>4)? 4 : SLITE_NUM;
and the same generate block, or
genvar sliteIfIter_grp1;
                  sliteIfIter_grp1<( (SLITE_NUM>4)? 4 : SLITE_NUM);
                  sliteIfIter_grp1++)
