Register Log in
[SOLVED] Synthesizing a 5-input AND gate, instead of three 2-input AND gates in xilinx ISE
radwa5
Newbie
Dear all,
I wrote a code that contain 5 input and gate, but the ISE synthesis tool used three two input AND gates in 3 levels instead of only one 5 input gate in one level,
What options can I change to synthesize my code using only one 5-input AND gate
andre_teprom
Super Moderator
Staff member
Brazil
I'm not familiar with logic design, but the question arises anyway: Is the requested 5-NAND gate available at the logic cells on the target device where you're synthesizing ?
TrickyDicky
Advanced Member level 5
Either its done logic minimisation with surrounding logic, or your device has only 4 input luts.
radwa5
Newbie
My device can support the 5 input and 4 input AND gate (it is virtex 6 )
when I write a code for 5 input and gate in a project alone, run the code it synthesize it as 5 input AND gate.
but using it in the carry look ahead adder code, they are synthesized as 2 input and gates
TrickyDicky
This has likely happened as logic reduction when the circuit is compiled.
radwa5
Newbie
I don't want this reduction, this leads to multilevel design and increased the time delay
is there an option to synthesis the code as it is?
TrickyDicky
Your assertion is unlikely, as the tools will try and meet the timing specifications you require. They will report if timing is not met in a synchronous design. An Asynchronous design is not recommended, as not only will the delay changed based on the logic, itself, it is also dependent on routing, temperature, voltage and the differences between parts.
barry
California, USA
Depending on the physical location of the gates, your 3-level logic might (probably is) faster than a single gate. As mentioned, the tool is going to try and meet timing and won't arbitrarily add more logic delay. Routing delay also figures into the implementation. If you've got a really dense design, the 3 gates might have been the best solution. But if you're hell-bent on using a 5-input NAND, then just instantiate it in your code with a KEEP (or similar) directive.
Toggle Sidebar
Design Fast
