cupoftea
Advanced Member level 5
We are making a device which switches up to 16A rms in the 240VAC mains into a device. It also needs to measure the 16A. We measure it with a Current transformer in mains live.
When we test the equipment, we currently load it up with a 16A load, so that we can see that it measures it properly. -But this means us dissipating 3.8kW in a dummy load during production test......not good.
Therefore, we wish to simply synthesize a 16Arms sine wave and shovel it through the current transformer, of course doing this while the live conductor around which the current transformer torroid sits is energized....it needs to be in phase with the mains voltage.
....We believe we can do this using a kind_of Class D amplifier stage with a 60V isolated DC input power supply as attached. it feeds into a 30V battery, but of course, there is no overall load in this as it receives AC current.
What do you think of this?
By the way, the control loop hasnt yet been completed in the attached.
(LTspice sim and pdf schem attached)
