Synthesis using Synopsis Design compiler
syed_dawood
Hi All ,
I am new to DC and looking for some help . At present I have a verified design which I have to synthesize . What clock frequency should be set for the design ??? In other words a general question would be can a design be synthesized at any frequency or is there any range of frequency which depends on the design itself .??
Thanks
chrisyl
Newbie level 2
Its up to your design requirements and the library you are using.
jirika
Member level 2
Prague
Yes there is the highest frequency based on SETUP time. And your frequency should be lower.
syed_dawood
Thanks Guys for the clarification , Also in case I have
library_PVT_1.db
library_PVT_2.db
library_PVT_3.db ... and so on . In other words I have a huge list of .db's each one of them specific to one PVT . In this case how do I add my library's ?? should I link all of them ? While mapping to cells from which .db will it pick up cells ??
Thanks.
chrisyl
Newbie level 2
Typically, use the slowest library in DC.
The best way is to ask the foundry for setup signoff corners.
mail4idle2
Full Member level 4
Please get the sign off corners and do run synthesi at that corner.
