avnish5mishra
Hi Al,
I have designed Traffic Light controller in that there is No warning or error but there are 12 synthesis Msgs are there. I just want to know how to Solve this.
Please Guide me As to how to remove this Synthesis Message
Xst:2117 - HDL ADVISOR - Mux Selector <state> of Case statement line 75 was re-encoded using one-hot encoding. The case statement will be optimized (default statement optimization), but this optimization may lead to design initialization problems. To ensure the design works safely, you can:
- add an 'INIT' attribute on signal <state> (optimization is then done without any risk)
- use the attribute 'signal_encoding user' to avoid onehot optimization
- use the attribute 'safe_implementation yes' to force XST to perform a safe (but less efficient) optimization
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 module Traffic_light_controller( input clk, input rst, output reg R1, // East Red output reg O1, // East Orange output reg G1, // East Green output reg R2, // West Red output reg O2, // West Orange output reg G2, // West Green output reg R3, // North Red output reg O3, // North Orange output reg G3, // North Green output reg R4, // South Red output reg O4, // South Orange output reg G4 // South Green ); parameter [2:0] state_1= 3'b000; parameter [2:0] state_2= 3'b001; parameter [2:0] state_3 =3'b010; parameter [2:0] state_4 =3'b011; parameter [2:0] state_5 =3'b100; reg [2:0] state,next; reg [5:0] count; initial count=6'b000000; always @(posedge clk) begin if(rst) count<=6'b000000; else if(count==6'b011111) count<=0; else count<=count+1; end always @(posedge clk) begin if (rst) state<=state_1; else state<=next; end always @(rst,state,count) begin R1=1; R2=1; R3=1; R4=1; O1=0; O2=0; O3=0; O4=0; G1=0; G2=0; G3=0; G4=0; case (state) // Line 75 on which it is giving message state_1: begin if(rst) begin R1=1; R2=1; R3=1; R4=1; O1=0; O2=0; O3=0; O4=0; G1=0; G2=0; G3=0; G4=0; next<=state_1; end else begin next<=state_2; end end state_2: begin if(count>=6'b000000 & count<=6'b000101) begin R1=0; R2=1; R3=1; R4=0; O1=1; O2=0; O3=0; O4=0; G1=0; G2=0; G3=0; G4=1; next<=state_2; end else if(count>=6'b000110 & count<=6'b000111) begin R1=0; R2=1; R3=1; R4=1; O1=0; O2=0; O3=0; O4=0; G1=1; G2=0; G3=0; G4=0; next<=state_2; end else begin next<=state_3; end end state_3: begin if(count>=6'b001000 & count<=6'b001101) begin R1=0; R2=0; R3=1; R4=1; O1=0; O2=1; O3=0; O4=0; G1=1; G2=0; G3=0; G4=0; next<=state_3; end else if(count>=6'b001110 & count<=6'b001111) begin R1=1; R2=0; R3=1; R4=1; O1=0; O2=0; O3=0; O4=0; G1=0; G2=1; G3=0; G4=0; next<=state_3; end else begin next<=state_4; end end state_4: begin if(count>=6'b010000 & count<=6'b010101) begin R1=1; R2=0; R3=0; R4=1; O1=0; O2=0; O3=1; O4=0; G1=0; G2=1; G3=0; G4=0; next<=state_4; end else if(count>=6'b010110 & count<=6'b010111) begin R1=1; R2=1; R3=0; R4=1; O1=0; O2=0; O3=0; O4=0; G1=0; G2=0; G3=1; G4=0; next<=state_4; end else begin next<=state_5; end end state_5: begin if(count>=6'b011000 & count<=6'b011101) begin R1=1; R2=1; R3=0; R4=0; O1=0; O2=0; O3=0; O4=1; G1=0; G2=0; G3=1; G4=0; next<=state_4; end else if(count>=6'b011110 & count<=6'b011111) begin R1=1; R2=1; R3=1; R4=0; O1=0; O2=0; O3=0; O4=0; G1=0; G2=0; G3=0; G4=1; next<=state_4; end else begin next<=state_2; end end default : begin R1=1; R2=1; R3=1; R4=1; O1=0; O2=0; O3=0; O4=0; G1=0; G2=0; G3=0; G4=0; end endcase end endmodule
