[SOLVED] Syntax problem around entity instantiation
madalin1990
Full Member level 2
Full Member level 2
I have described a top for my implementation but got stucked on this error:
"Syntax error near "Instance_dpim_IO".
I have scanned the code but can't find any syntax error.Here is the code near "Instance_dpim_IO" :
signal Sw1   : std_logic_vector(15 downto 0);  -- 0x05..6  16 switches, bottom row on the PC I/O Ex GUI
signal Btn1 : std_logic_vector(15 downto 0);  -- 0x07..8  16 Buttons, bottom row on the PC I/O Ex GUI
signal dwBtwn: std_logic_vector(31 downto 0); -- 0x09..b  32 Bits user output
------------------------------ component's instantiation -------------------------------------
Instance_dpim_IO: dpim_IO port map(
      mclk 	 => mclk,
      EppDB	 => EppDB,
      EppAstb=> EppAstb,
      EppDstb=> EppDstb,
      EppWr  => EppWr,
      EppWait=> EppWait,
	  data_out=> dpimref_mem,
	  data_in => mem_dpimref,
	  address => tmpAddr,
      Swrite => tmpWr,
      Led    => Led1,
	  LBar    => LBar1,
	  Sw      => Sw1,
	  Btn     => Btn1,
	  dwOut   => dwBtwn,
	  dwIn    => dwBtwn
Instance_ram_sp_ar_aw: ram_sp_ar_aw port map (
        address => tmpAddr,
        mem_in  => dpimref_mem,
Nevermind. I have forgotten a begin.:D
Yeah! I don't know how this happens! I see the answer only after I post it on edaboard :D
