Syntax error near "when"
mo.khairy.mo
Member level 2
Egypt
hi all
what's the error in this vhdl code
when (opcode = addu) =>
	   I0 : int_2s_add_sub
      PORT MAP (
         clk           => clk,
	 enable      => '1',
         rst           => rst,
         opa         => opa,
         opb         => opb,
         M	       => '0',
         OVF 	       => flags(5),
         opc 	       => opc
if i need to port map some components depend on conditions how can i do it?
thanks in advance
use block statement . depending on the "guarded " condition assignment will take place
Use the generate statement instead of your when:
g0: if (opcode = addu) generate
I0 : int_2s_add_sub
PORT MAP (
clk => clk,
enable => '1',
rst => rst,
opa => opa,
opb => opb,
M => '0',
OVF => flags(5),
opc => opc
end generate;
thanks all
@balavinayagam
could u please support me with an example
@devas
i try what u suggest and i have the following error
"generate condition is not constant"
how can i fix it ?!
That's a problem. The generate condition must be static, i.e. it cannot include signals. I was forgotten this. I do not know if you can change the condition so it becomes static. Maybe the block suggestion will work but I have never used block statements so I have no idea.
Success, Devas
please could u explain what do u mean with static?!
