Advantage of Synplify Pro:
- Able to generate smaller & efficient digital netlist.
- Save the PC resource because you no need to open ISE when doing synthesis.
- More flexibility on setting the attribute & behaviour of digital circuit.
Disadvantage of Synplify Pro:
- Extra pay for software license.
- It change the netlist name which is not identical to netlist generated by XST.
For experienced FPGA designer, we all prefer to use Synplify Pro because it work perfectly and less bugs in software tool.
synplify sometimes give better result than the xst ,but i think xst will be gettin better for its own products , since the new architecture is used in v5 ...
Synplify supports Systemverilog for synthesis.
Xilinx XST (ISE) doesn't support Systemverilog (yet) -- Xilinx claims to begin Systemverilog synthesis in 2008. And it will probably be many more releases before the Systemverilog-support is good enough for real project (non-academic) use.
I like Altera Quartus-II for this reason -- it already support Systemverilog well enough to use on small projects.
advantages of synplifypro over XST
faster runtime,
Increased performance,
Effective algorithms for FSM extraction etc....
When a bigger design is considered Synplifypro is best compared to XST in all aspects
