synopsys synthesis error in DESIGN COMPILER(DC)
priyanka24
India
HI...
am synthesizing my vhdl code in design compiler in that during elaboration i got following error::
/home/student1/SNPS-2/source/golombcoding.vhd: 72 constant value required.
description of error is as shown below.
priyanka24
India
there maybe error in code....................... not in the synthesis
but i checked my code and me not got any error in syntax checking and also i got correct simulation results..
priyanka24
India
me synthesized my code in xilinx ISE its synthesizabe there.
its not getting synthesize in synopsys design compiler..
can anybody knows what solution for my error???
---------- Post added at 22:27 ---------- Previous post was at 22:17 ----------
graphene
Full Member level 2
Germany
perhaps we need the code to find out the bug... some codes dont get synthesis though they get simulated
priyanka24
India
yes, but me synthesized my code first in xilinx. there its got synthesized.
but in synopsys design compiler not getting..
so plz let me know what is problem..??
graphene
Full Member level 2
Germany
it also depends on the technology you use..... I can try the same in Cadence 4 you if u want to cross check..
as a fact, I dont have a genaralised reason/solution for this...
priyanka24
India
yes can you do it?
graphene
Full Member level 2
Germany
Yes I can.. its already 1930 Hrs here.. so if you can share the code, by tmrw I shall evalutate and let you know.. also share the test bench codes for us to have a hand on simulation as well..
priyanka24
India
yes can you do it?
okay
i will send to you.
also plz try to find in synopsys design compiler tool if anybody knows it??
---------- Post added at 23:01 ---------- Previous post was at 22:59 ----------
yes i will send to you.
also try to find out in synopsys if anybody knows it.
