Hi Everyone,
I'm trying to synthetize my circuit composed by several submodules and I've created a clock using <create_clock -name "CLK" -period 5 CLK> in my very top level, but when i go inside a submodule and go to check the clock there the shell says that the current design has no clock constrain, as it is not connect from the top level. Should I create a clock for each submodule or is this behavior normal?
Yes, I mean when I simulate before the synthesis circuit works correctly. Also when I try to <report_clocks> from the top level it gives the name of the clock that I've created before, but when I write in dc_shell:
Hi kls,
Current design basically "switches" to another design, and does not go deeper into the hierarchy. What you should be using instead is "current_instance top/hier_you_are_interested/module"
