S0syk
- Joined
- Apr 20, 2012
- Messages
- 5
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,352
Hello Everyone,
I curently working on adjustable constant current source with LT3741. Design specifications are:
Input voltage: 10 V - 15 V (lead battery)
Output current: 0 A - 3,3 A
Maximum output voltage: 5 V
Switching frequency: 200 kHz
Schematic:
Parts were chosen with datasheet equations and advices:
http://cds.linear.com/docs/en/datasheet/37411fd.pdf
Without a load i got nice 5.06 V ouput over whole input range.
Voltage waveform of switching node at high and low input volatage:
Problem is when i connect load i get waveform like this with audible noise from inductor.
With 1.8 ohm load I tested from lowest input current (Vctrl1 set to minimum). Power supply is working fine till about 1A (also regulating well over input range). Over 1 A there are again oscilations like on the picture and supply dont ragulate well. Are these subharmonic oscilations? LT3741 using average current mode control and gm OPAMPs.
I used equations from datasheet to calculate R14 and C11.
I think problems can be caused by:
a) bad layout (huge noise)
b) bad compensations parts (i know i need to set the downslope of the current signal comming into PWM comparator to be lower than slope of the PWM ramp, but i dont know if i did it properly)
I tried different values for R14 and C11. Nothing changed.
Here is layout:
top
http://www.dropbox.com/s/a4hfaaefjeu9z6o/top.png
bottom
http://www.dropbox.com/s/qxu0jzsfmqe9o17/bottom.png
Anyone have experience with average current mode compensation or with LT3741? Any advices? Thank you
Schematic:
Here is layout:
top
bottom
