Synchronous and Asynchronous Design
kunal1514
Full Member level 1
Hi All,
Can any body tell me that Whether Asynchronous or Synchronous Design consumes more power.
kishore2k4
Full Member level 5
Middle Earth
Well Asynchronous design is supposed to consume less power, its the main research goal for all asychronous vlsi design groups. They do have their share of problems.
In normal circuits you can combine both with proper interface logic, I guess.
http://jungfrau.usc.edu/new/index.html
yesme@
Member level 1
Asynchronous circuit may consume less power than synchronous circuit. But it's not true for all cases.
linuxluo
Full Member level 6
hi,
yes , asyn comsume more power but if you use eda tools to do job you have to use synch circuit becoz of capability of eda tools
deva_eda
Member level 1
The anser to the question is application specific. Anyhow to generalize, synchronous designs are more power hungry than asynchronous design. As the clock network consumes the major power in synchronous designs.
As other memebers have mentioned designing an purely asynchronous design is very challenging and for any information you may try googling to read the ongoing research work.
laglead
Full Member level 5
It may be the same in average power. But synchronous consume much larger power at clock rising or falling edge, which will lead to power integrity problem.
funster
Full Member level 4
In synchronous circuits, 50% of power is consumed by clock tree,
because there is no clock tree in asynchronous circuit, so asynchronous circuit
consume less power.
kunal1514 said:
Hi All,
aswin123
Junior Member level 2
i agree with asynchronous designs consume less power.
due to this in every design we can use asynchronous design only or synchronous also some times.
what r the advantages in syncronous compared to asyncronous ........
calm
Full Member level 4
FLEXcertifydll
Full Member level 4
saving power U must cost design time, that is to say U must take some challenge tech
