Synchronizers @Synthesis and @STA
ivlsi
Advanced Member level 3
Hello All,
How to define constrains on the synchronizers during the synthesis and STA?
Besides the set_false_path, should be set_multicycle_path be defined as well? Why?
Thank you!
first method: set_false_path -from [get_clocks CLK1] -to [get_clocks CLK2]
second method: set_clock_groups -asynchronous -group {CLK1} -group {CLK2}
So, setting multi-cycle paths on the synchronizers is not necessary?
not necessary
Reactions: ivlsi
    ivlsi
I have even seen designs that work without setting false path as well.
You have to see this
https://opencores.org/websvn,filedetails?repname=ac97&path=/ac97/trunk/syn/bin/comp.dc
I am also pasting the script that does the real synthesis. "Note there is no false path or multicycle path command."
# Actual Synthesis Script
# This script does the actual synthesis
# Author: Rudolf Usselmann
# rudi@asics.ws
# Revision:
# 3/7/01 RU Initial Sript
# Setup Design Parameters
source ../bin/design_spec.dc
# Setup Libraries
source ../bin/lib_spec.dc
# Setup File IO
set junk_file /dev/null
append log_file ../log/$active_design "_cmp.log"
append pre_comp_db_file ../out/$design_name "_pre.db"
append post_comp_db_file ../out/$design_name ".db"
append post_syn_verilog_file ../out/$design_name "_ps.v"
sh rm -f $log_file
# Setup Misc Variables
set hdlin_enable_vpp true ;# Important - this enables 'ifdefs
# Read Design
echo "+++++++++ Reading Design ..." >> $log_file
read_file $pre_comp_db_file >> $log_file
# Operating conditions
echo "+++++++++ Setting up Operation Conditions ..." >> $log_file
current_design $design_name
set_operating_conditions WORST >> $log_file
# Setup Clocks and Resets
echo "+++++++++ Setting up Clocks ..." >> $log_file
set_drive 0 [find port {*clk}]
# !!! WISHBONE Clock !!!
set clock_period 5
create_clock -period $clock_period clk
set_clock_skew -uncertainty 0.1 clk
set_clock_transition 0.5 clk
set_dont_touch_network clk
# !!! BIT Clock !!!
set clock_period 500
create_clock -period $clock_period bit_clk
set_clock_skew -uncertainty 0.1 bit_clk
set_clock_transition 0.5 bit_clk
set_dont_touch_network bit_clk
# !!! Reset !!!
set_drive 0 [find port {rst*}]
set_dont_touch_network [find port {rst*}]
# Setup IOs
echo "+++++++++ Setting up IOs ..." >> $log_file
# Need to spell out external IOs
set_driving_cell -cell NAND2D2 -pin Z [all_inputs] >> $junk_file
set_load 0.2 [all_outputs]
set_input_delay -max 1 -clock clk [all_inputs]
set_output_delay -max 1 -clock clk [all_outputs]
set_input_delay -max 1 -clock bit_clk sdata_in
set_output_delay -max 1 -clock bit_clk sdata_out
# Setup Area Constrains
set_max_area 0.0
# Force Ultra
set_ultra_optimization -f
# Compile Design
echo "+++++++++ Starting Compile ..." >> $log_file
#compile -map_effort medium -area_effort medium -ungroup_all >> $log_file
compile -map_effort low -area_effort low >> $log_file
#compile -map_effort high -area_effort high -ungroup_all >> $log_file
#compile -map_effort high -area_effort high -auto_ungroup >> $log_file
# Write Out the optimized design
echo "+++++++++ Saving Optimized Design ..." >> $log_file
write_file -format verilog -output $post_syn_verilog_file
write_file -hierarchy -format db -output $post_comp_db_file
# Create Some Basic Reports
echo "+++++++++ Reporting Final Results ..." >> $log_file
report_timing -nworst 10 >> $log_file
report_area >> $log_file
I have run the design myself. The synthesis script works and the design is correctly synthesized.
Reactions: ivlsi
    ivlsi
set clock_period 5
# !!! BIT Clock !!!
If the 2 clocks are synchronous (generated from same source) and edge-aligned:
1. There will no metastability possibilities due to unaligned edges that is the case with asynchronous clocks. So false paths need not be set.
2. Since false path is not set, timing analysis will proceed as it normally does for single-clock designs. There is the possibility of metastability due to setup-hold violations arising out of heavy delays from combinational paths, clock skew etc. Setting multi-cycle constraint may help solve this by letting the tool know that the capture clock edge (either of 5ns or 500ns clock) need not be the immediate next edge after the launch clock edge (which is the default).
If the 2 clocks are synchronous but out of phase (not edge-aligned), I think the phase relationship is probably known not to cause metastability ever and hence no false path has been set in the script. I'm not absolutely sure of this though.
If the 2 clocks are asynchronous, false paths have to be necessarily set.
Am not a synthesis guy hence cannot tell what is the clock relationship from the script.
The false paths for the synthesis are NICE TO HAVE, not a MUST. If you don't set false paths for the synthesis, the synthesis tool will just spend more time for the synthesis - that's all! If that is not a matter for you then of course you HAVE NOT set false paths at all.
Hope this help
If they are not set, not only more time will be spent by the tool, irrelevant violations will be reported in the asynchronous cross-clock paths, debugging which will add more time to reach a clean netlist.
Agree with you. I actually meant a possibility not to define the false paths, but also define aligned clock edges.
