div
Member level 3
symbolic circuit simulator
Hi there:
Sometimes, I need to find the multi-port Z(Y,S,T) matrix
from a circuit netlist (Spice netlist).
Then the questions are:
1) Can circuit simulator(Hspice) give a multi-port Z(Y,S,T) matrix
output?
Suggestions as how to combine several 2-port matrix into
multi-port matrix technique are also welcome.
2) I not only want to find the numerical solution but also
want to find a symoblic solution. Is there any circuit simulator
being able to do that?
For example, I have a 2-port network as below
--L ------L--
C
---L ------L--
I can manually calculate the Z(Y,S,T) matrix with a
symbolic expression. But how about a network with
hundreds passive elements? Any suggestion/idea?
If there is no such kind of tool, I may consider to
write a freeware to do that. )
Div
Hi there:
output?
--L ------L--
C
---L ------L--
Div
