symbol creation from schematic in cadence
prasadel06
Member level 2
hi....
i am doing the project on flash adc in cadence virtuoso schematic...
i want to create the symbol from the schematic of comparator and i want to change the
properties of the that circuit through the symbol..
how can i create the symbol which can be editable ......
please help me.....
thank you...
prasad.
277897909
Junior Member level 2
For transistor design the circuit is fixed,then what parameter do you want to set?
If you want parameter editable you can molded the sysetm using verilog-A.
Fom
Advanced Member level 2
Taiwan
In schematic put
pPar("Property_name")
instead of numbers for properties you want to change on the higher level of hierarchy.
Then in Virtuoso Schematic Editor menu select
Design -> Create symbol
From View Name -> schematic To View Name -> symbol
The symbol will be generated with properties trough which you can propogate their values to lower level of hierarchy.
Good luck!
    prasadel06
raj_shekar
Junior Member level 1
1) Go to DESIGN-->Create Cell view.
You wiil get a symbol.
Then create a label and write the parameters which u used in the schematic.
Ex: if nmos width is the parameter, enter "[@wn]" in the width of the nmos instance in schematic. Next create a symbo,l Create a label as"wn=[@wn]" in the symbol window. similarly create other parameters.
when u use that symbol in other schematic, write as "wn = 1".
batistuta
Full Member level 1
raj_shekar is right, you can try..
ramaro
can any one give me information about simulation
thanks
