Switching on/off devices with Triac+relay
Zedman
Full Member level 6
Hungary
triac relay
I would like to turn on / off a couple of devices (TV, HiFi) etc with a Triac + Relay combo.
The triac will turn on at zero cross, after that a parallel relay will turn on and after a small time triac will not be triggered anymore.
Same way when turning it off.
I read that there can be problems switching inductive loads with triacs.
This on/off event is going to happen just 0-20 times a day.
Do I need any extra precaution / snubber RC etc, to switch these appliances safely?
thanks,
Zedman
triac switching
may i know what your exact logic,with a pictorial representation if possible.
does both triac and relay needed for such a switching application.?
triac or relay
It's quiet simple scenario, just a bistable relay in parallel with a triac. I would like to use the triac to prevent the relay switching on in the middle of a sine wave.
But after that I don't want to use the triac because the relay is bistable and needs no energy to hold the ON state.
thanks,
Zedman
on off con triacs
I guess there will be no problem as you are switching the loads with both the triac and the relay in parellel. The switching of inductive load is a problem with triacs only when you try to control the inductive equipment (Vary the speed for Eg). If you are switching the load On/Off only, i think no problems will be faced. But as a matter of safety for EMI and RFI, use snubbers and MOV's. Hope this helps you. Dont forget the "Helped me" Button. Good luck.
triac relays
A triac in parallel with a latching relay will assure that the switch is made at a zero-crossing, but the triac must remain energized until the relay contacts are closed.
A TYCO KUL-type latching relay claims an an operating time of 25 mSec max, so the triac needs at least two cycles of gate-drive.
Wade Hassler
triac as relay
thanks, I am using a Schrack PE014A05 relay, the switching sequence looks like this:
1) Triac ON
2) wait 50 ms
3) Relay coil ON
4) wait 50 ms
5) Relay coil OFF // by this time the relay has switched it's state
6) wait 50 ms
7) Triac OFF
relay control with triacs
seems it doesnt create any problem.
have fun...
