Hello,
I am working on a project where I wanna switch between LED’s. The problem is I don’t now anything about programming at school we are going to work with flowcode so if maybe somebody can help me that works in flowcode.
I think for the people that has programmed some more things it is easy for them?
This is what I’ts need to do:
When I put the power on the Led’s needs to be out.
When I push 1 time on the switch led1 needs to be switched on.
Another push on the switch Led 2 needs to be ON and led1 out.
Another push Led 3 ON, led 1&2 off.
And another push all leds needs to be out.
And then start over again at the beginning.
Below is the schematic of it:
I don’t now if there is a possibility that someone can write a code in flowcode?
With best regards,
Koen
