Switchig power supply....
Rfboy
Member level 1
1000w mc34262
Hi, I'm looking for a project or information about a switching power supply with these caracteristics:
- Input : 110-260 Vac
- Output : 48 Vdc 18 A
with PFC.
Thank you
mc3842 power supply
you can modify a standard computer supply by changing a few components
to be satisfactory
mc3842 smps pdf
to be satisfactory
put your email i will send you pdf files.
haymeron@hotmail.com
with PFC.
Thank you
@haymeron:
Why don't you upload the to the fileman?
haymeron
If its not too much trouble please upload to Fileman and post link also in 'general datasheets' forum
thx
JR
Hi
Piece of cake
Just use a ST Viper100 with a low input
cap, like 4u7 running at 180khz.
Will suit nicely.
Get the info and all here:
Best
PadsPCB
Pads
ST Viper????
What about TopsSwitch from PI, better thermal, EMI character and lots of transformer ready made available from Premier Magnetics.
http://www.powerint.com Link also their for Premier as well.
Just suggestion
JR
@SIMBOX
48V * 18A = 864W !!!
I don't think a PC-Power-Supply can be modified to deliver this output power.
kind regards
thomaz
hi.
a flyback topology is not suitable for
high power over 300W.
the stress on the transistor and the output dioder is very high
especialy at low input voltage.
i suggest you to use mc34262 for the
pfc for the first stage with output
voltage at 400V.
for the second stage use a forward
current mode topology, use mc3842.
infineon (simenes) have one chip for
this work.
look also at https://onsemi.com
sorry, i dont have now the time to upload.
if you want to upload pdf files on switching
power supplies including pfc and other topologies.
i will post you my login and password at freedrive.
regards - haymeron
in addition.
i think that a resonance converter in
the second stage will be more efficient.
haymeron
This web site features SMPS technology.
Unitrode (now Texas Instruments) has lots of appz notes and components.
http://www.unitrode.com/
j235r:
Thanks for the link, just what I'll be needing on my next project.
I think a PFC(using UC3818 controller) + Phase shift full bridge DC/DC converter(using UC3875) can do this job.
Designing a 1000 watt AC_DC converter is a tricky affair
with an estimated efficiency of 75% the power desipated is in the range of 250 watts if the required qty is low you can try using multiple SMPS module in series or parallel combination :roll:
but as the power of the converter is increasing ,how can the heat be dissipated
