switched opamp comparator
nodame123
Member level 1
Member level 1
In the circuit of a switched op amp,there are many bias voltages(i guess) to be given. I don't have any idea abt how much to be given.LTspice simulation of the comparator just shows a plain 0 for the dc sweep of input voltage.
Could anyone help me with this..please,it's sort of urgent..
circuit is in pg-76
thank you..
  • 142 (1).pdf
Generally the different bias inputs are there for you to adjust until a 'good operating point' is found.
The purpose is so that your circuit will accept a range of input signals which you feed it, and produce a usable output.
Some of the mosfets are like a variable resistor.
One bias might need to be adjusted depending on the supply V.
Another to adjust current through a long-tail pair.
Others might need adjusting depending on how much DC is riding your input signals.
Another to alter gain.
Another to provide a desired positive current range to the output load. Or a negative current range.
Another so you can obtain zero output with zero input. Or else perhaps perform a volt level shift.
Etc.
