switch case help!!!!
paddy_p
Mumbai India
I am using switch case function in code.
Can i use multiple statements in each case or it should be single statement in each case?
thanks,
paddy
Please refer below mentioned code
switch(i)
               case 0:
               output_high(pin_B7);        //turn on LED
               output_high(pin_A2);        //clock to latch
               delay_us(100);
               output_low(pin_A2);
               delay_us(100);
               output_low(pin_B7);        //turn off LED
               delay_us(100);
               output_low(pin_A2);
               delay_us(100);
               break;
               case 1:
               output_high(pin_B6);
               delay_us(100);
               output_low(pin_A2);
               delay_us(100);
               output_low(pin_B6);
               delay_us(100);
               output_low(pin_A2);
               delay_us(100);
               break;
Is it valid?
can u post the full code and what is excepted output......
I am just checking for alarm condition and if it occurs i have to blink the LED.
To do this i am toggling port pins in every case.
So i have written same cases for 8 values.
the code looks fine but what is output u are getting now
I just want to confirm that switch case supports multiple statements or not.
And i don't have hardware ready with me to check the output.
switch(i)
               case 0:
               delay_us(100);
               output_low(pin_A2);
               delay_us(100);
               delay_us(100);
               output_low(pin_A2);
               delay_us(100);
               break;
               case 1:
               delay_us(100);
               output_low(pin_A2);
               delay_us(100);
               output_low(pin_B6);
               delay_us(100);
               output_low(pin_A2);
               delay_us(100);
               break;
Is it valid?
Yes, it's fine.
I like to keep the statements in the case within parentheses. But, that's a matter of personal preference and isn't necessary. Your code is fine.
I have to make an indication device which has 120 LED's.
I have connected that LED's to one port of micro controller via 74HCT574 and ULN2004.
i.e Micro controller port -> 74HCT574-> ULN2004 -> LED's
For 120 LED's I have used multiple 74HCT574 IC'c and ULN2004 IC's.
I am sending common data on all 74HCT574 and enabling particular 74HCT574 by giving clock to it.
Is this circuit okay? And should I get enough intensity?
Please suggest.
thanks,
paddy
