Aug 9, 2017 #1 A Ayman Essam Member level 2 Joined Jun 16, 2015 Messages 43 Helped 2 Reputation 4 Reaction score 2 Trophy points 8 Activity points 295 Hi my opamp's open loop gain is above 60 dB's, and the In/out common-mode voltages are stable in the mid-scale of VDD, but the output differential of the integrator is very close to VDD !!! any help with that ?
Aug 9, 2017 #2 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,394 Helped 14,748 Reputation 29,778 Reaction score 14,091 Trophy points 1,393 Location Bochum, Germany Activity points 297,975 What's the test circuit? Did you notice that an integrator can't achieve a stable output bias without external negative feedback?
Aug 12, 2017 #3 A Ayman Essam Member level 2 Joined Jun 16, 2015 Messages 43 Helped 2 Reputation 4 Reaction score 2 Trophy points 8 Activity points 295 FvM said: What's the test circuit? Did you notice that an integrator can't achieve a stable output bias without external negative feedback? Click to expand... I am using switch-cap circuit
