Switch Cap Array using Series Cap
celebrevida
Member level 3
Member level 3
I am in the middle of designing an 8-bit SAR-ADC using a switched cap DAC.
The most straightforward way is for the caps to be binary weighted and you would have a situation as follows:
128C, 64C, ..., C
for a total of 255 capacitors in total.
It seems I could reduce the number of caps significantly if I used caps in series:
8C, 4C, 2C, 1C, C/2, C/4, C/8, C/16
where C/2 means 2 caps i series, etc.
The end result is 8+4+...+8+16=45 capacitors in total.
Is there any issue with using caps in series like this?
Also would I need or want to precharge the middle nets to 0V and then let them float? Or is precharge not needed?
Thanks in advance!
The big "art issue" may be accounting for stray C
(a shunt loss / error term). You put the explicit caps
in series but not the shunts. So the end-to-end C
will not be exactly 1/N the lonely C.
Easy to match shunt to shunt, everything's parallel
to the same place. Shunt to series, there's the
topology messing a bit.
IIUC, the "internal nodes" in the caps that are in series cause mismatch as these nodes do not exist in the caps that are not in series.
In that case, perhaps a good compromise might be something like:
32C, 16C, ..., C, C/2, C/4 (total of 69 caps)
or even
64, 32C, ..., 2C, C, C/2 (total of 129 caps)
might be preferred.
Assuming that LPE would catch the stray internal node capacitance, I could see if 32C, 16C, ..., C, C/2, C/4 (total of 69 caps) is good enough.
LaTeX Commands Quick-Menu:
