emyles
Hi all,
I’ve a problem to integrate a mixer, BCO and IF signal of 10MHz as the inputs.
However, the result obtained was as shown in Picture 001 in the attachment.
Is the result correct? Shall the output be a single mixed spectrum (4.803GHz) only? I suspect it is due to LO leakage problem.
What should I do to get the correct output signal?
Picture 005 shows the spectrum of the IF BPSK signal (10MHz)
Any help and advise is appreciated.
Thanks
Thanks
