At a guess, if V1 = V2 then I1 = I2 then the current source is balanced and stable. Think of it as a balancing act, or a see-saw, or a rocking boat - up on one side is down on the other. I might be wrong but I play with current sources s frequentlyand the Wilson one isn't as good as might be wished for.
IMHO, assuming the mysterious bubbles are resistors or similar, that is not a truly supply-independent current source, at all, and nor is it temperature-independent, either. Greater Vin = greater I1 & I2 = higher V1 and V2.
If you want to see a super supply-independent currrent source, look for older versions of lm2903, lm339, etc. comparator datasheets for link to app note describing how those devices source is constructed, truly superb thing.
If you are making a reference from a Wilson mirror, good to ponder PTAT and absence of CTAT...
My mobile signal is too weak to upoad the app note I mentioned above. Here's the link:
snoa654A It'll possibly offer to download a pdf, it is from TI, safe...
Document is "AN-74 LM139/LM239/LM339 A Quad of Independently Functioning Comparators", aka snoa654A - May 2004 - Revised April 2013. Current source explanation is bottom of page 4 to midde of page 5.
