neoflash said:for Superheterodyne receiver, why not directly down convert the band to baseband?
mowgli said:Hi all
another advantage of Superheterodyne receiver arises if you have to select a narrowband channel (Δf of some kHz) in a frequency band B of several MHz: with Superheterodyne you can split the high Q requirement you would need for the channel filter (Q = B/Δf) betweeen RF and IF filters. You can use a RF filter with a low Q to select the band B (or a tunable filter to select only a part inside the full band) and after IF conversion you can implement a fixed frequency filter (i.e. SAW filter) with very good Q with less cost and better performances than if you do direct selection of the channel inside the band B with a tunable filter with same Q.
Another advantage is that the IF frequencies often are standardised and so there are a lot of components available on the market.
Mowgli
throwaway18 said:As dch316 says high RF gain without oscilation is easier with a superhetrodyne receiver.
The other main reason is image reception.
Consider a simple direct conversion receiver (not I/Q) which receives an FSK signal using 450.005 to represent a zero and 450.010 to represent one.
You can use a local oscillator of 450.000MHz to convert that to baeband giving 5Khz for a 0 and 10Khz for a one.
Suppose that there is another transmission in the next channel down occupying 449.98-449.99
That is too close to filter out in the bandpass filtering before/after the LNA.
The unwanted signal ends up in your baseband output.
If it is a true direct conversion receiver, then there is no image problem! If you remember, image is always located at 2*IF away from the desired signal. If IF=0Hz, where is the image?
lguancho said:If it is a true direct conversion receiver, then there is no image problem! If you remember, image is always located at 2*IF away from the desired signal. If IF=0Hz, where is the image?
But we do have DC offset problem to solve, for example, LO leaking to the antenna, get reflected and remix in the mixer.
Some architecture is talking about low IF to resolve this DC issue.
