sn_burki
Full Member level 5
I want to make a simple volt meter with some components for my UPS monitoring ranging from 0.00V to 25.00V.
Can any one suggest a very simple one.
Thanks for your kind reply,,,umery2k75 said:I am not sure, whether Volt meter with 2 significant figure precision will consist of just a few components.
I don't know if there's an voltmeter IC available, that can make your circuit with least number of component.
Here's some one circuit.
https://www.coolcircuit.com/project/meter/
As an advice,why don't you just buy the ready made Volt meter, they are cheap though, including both analog + digital.
https://www.futurlec.com/Panel_Meters.shtml
You can have another option of using ICL7106, its a complete Volt meter and easily available. It is for LCD display and for LED display you can use ICL7107.sn_burki said:I want to make a simple volt meter with some components for my UPS monitoring ranging from 0.00V to 25.00V.
Thats right,,, I am using it in UPS for the battery level check. My mean aim is to understand that how uc works with A/D in volt meter and current meter. I really want to use an external A/D network with Atmel 8051.umery2k75 said:@garg29
We all didn't notice that
I think he might be using 2 * 12 V batteries=24Volt DC. Mostly found in UPS system. So maybe he want's to measure from 0-25V. I think this voltage level refer to the DC voltages of the battery.
