flyinspace
Full Member level 2
Hello, everyone
I am designing a difference Ring VCO in CMOS 0.35um process. It's main specs are below:
Tuning range:10M-150M with wide input control voltage, 5v power supply, lower phase noise(I am not sure about the exact value, it is better when lower), better power supply suppression, good substrate noise suppression, output is square wave with 50% duty cycle
My design attaches important to the lower phase noise & better power supply suppression. At the same time, I select the difference Ring VCO due to the low frequency application. Who can give me some hints about the detailed achitecture? To abtain the better performance, how many stages is appropriate(3 or 4 stages)?
If you present a suggestion, please post your reasons together.
Thanks in advance.
Thanks in advance.
