is there any simulator for AT89S8252 micro controller ic .............so that i may be able to check if my program is producing a output...........????
proteus is the most famous simulator for analog and digital circuit. If you use the c language u can use keil c compiler to create hex files and proteus to simulate them... Good luck
Hi My Friend
what is the compiler you use.... note you can use PROTEUS with only hex file independent of the compiler ... but lets know you compiler may we can help more
