hansika said:Hi,
thanks for your suggestions,i have a doubt some of microcontrollers suggested by you people are operated in the range of 0-3.6V, but as i told you my ADC and DAC should be operate on 0-5V,if the microcontrollers are operate on 3.6V may i give 5V to ADC pin if not , please suggest me microcontroller which will operate on 5V and it should be having above features.
Totally. Always use what you think would suit you best, cause all of them are very good chips.srizbf said:choose any one , PIC , atmega or arm whichever is suitable to you.
I guess this depends a lot on where you live or work and the popularity of the microcontrollers at that location. Over here a PIC12F675 is the same price as an ATmega8, ATmega88 slightly more expensive and an 18F2550/4550 about 4 to 5 times as expensive. So you see what I mean.srizbf said:PIC is always less costlier in some version , if cost is the factor for you.
I don't know about ARM, but dsPIC33, PIC24, PIC32, AVR32, ATxmega all operate at <= 3.6v. Of course, there is an exception: the dsPIC30.anandpv2009 said:Logic high of most 16bit/32bit controllers are less than 5v (<=3.6v).
Tahmid said:I guess this depends a lot on where you live or work and the popularity of the microcontrollers at that location. Over here a PIC12F675 is the same price as an ATmega8, ATmega88 slightly more expensive and an 18F2550/4550 about 4 to 5 times as expensive. So you see what I mean.srizbf said:PIC is always less costlier in some version , if cost is the factor for you.
Tahmid said:I don't know about ARM, but dsPIC33, PIC24, PIC32, AVR32, ATxmega all operate at <= 3.6v. Of course, there is an exception: the dsPIC30.
Tahmid.
hansika said:Hi,
